1. Tom Bradburn's Avatar
    I've recently changed to android and my car is showing no song information is this an issue with android 8.0? If so, anyone know how to fix it? I have a Sony Xperia xz premium.
    03-05-2018 01:44 PM
  2. SpookDroid's Avatar
    What music app are you using? Have you tried it in a different car system? How are you connecting the phone to the car unit? The app you're using is usually the one in charge of what info is sent over to the audio unit, but it could also be a bug with the specific car system or the way you're connecting things.
    03-05-2018 05:52 PM
  3. Tom Bradburn's Avatar
    using either the default music player or Spotify, happens on both. haven't tried a different car. I am connecting to the built in audio unit.
    03-06-2018 07:13 AM
  4. SpookDroid's Avatar
    Have you tried removing the pairing from your phone and then re-pair the device and the car unit? Do track controls work or are those not doing it either?
    03-06-2018 12:44 PM
  1. Pro/Cons to buying unlocked phone on Tmobile
    By Android Central Question in forum T-Mobile
    Last Post: 03-20-2018, 12:12 AM
  2. Anyone had screen failure on their Pixel 2?
    By psteve2005 in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 03-11-2018, 10:41 AM
  3. why can't i move my apps or picture on my sd card anymore?
    Last Post: 03-06-2018, 03:29 PM
  4. Phone locked on emergency call? Don't know password? Any suggestions
    Last Post: 03-06-2018, 01:49 PM
  5. Show two apps at once on Android 5.1.1?
    By King Mustard in forum Ask a Question
    Last Post: 03-06-2018, 08:26 AM
