1. wayneb64's Avatar
    I use my Galaxy Express Prime 2 very little and have been lasting almost a week before needing a recharge. Now it's like 2 plus days. The power use after 2 days shows a few apps at a few percent with Android itself taking the most at like 14%. Nothing is standing out.
    If I go into max power saving mode it says it will last like 7 days but I don't want that dark theme that takes away all my app icons. How do I engage the speed limiter without the dark theme and why do I need to now?
    Thanks for any help.
    (Repeat question now that I am logged in)
    More information. The Max power save mode says it will add 5 more days but it FORCES me into Dark Theme which I do not want. Mid mode says it's CPU limiting to 70% and Max says it will do 60% and save a TON of battery life. I want to try that but not lose all my apps in Dark Theme.
    11-21-2018 09:04 AM
  2. Rukbat's Avatar
    Is https://forums.androidcentral.com/as...infuse-4g.html your original post? If so, there's an answer there.
    11-21-2018 02:29 PM
  3. wayneb64's Avatar
    My battery is down 15% in like 7 hours and usage shows 32 m of screen for 1%, Android System for 1% and Device idle for 6 h 48 m for another 1%. Where did the other 12% go??? I have rebooted twice and I noticed the first reboot cost 5%. Makes no sense.
    I ordered a couple new batteries, hoping maybe my battery is worn out, but I hardly have used the phone over the last year or two.
    11-21-2018 03:14 PM
  1. LG G6 Battery life is draining fast
    By Rami1996 in forum LG G6
    Last Post: 11-22-2018, 12:24 PM
  2. Some recent update has more than tripled my battery drain on my Infuse 4G
    Last Post: 11-21-2018, 03:12 PM
  3. How can i remove headset icon from my notification bar
    Last Post: 11-21-2018, 02:20 PM
  4. No update
    Last Post: 11-21-2018, 02:16 PM
  5. My finger print app is missing in my coolpad note 5.
    Last Post: 11-21-2018, 09:06 AM
