Need a widget to turn on Airplane Mode.
enginestar
Active member
Apr 22, 2018
37
My phone has recently been updated to android 8
I used to have a widget that turned on and off just by pressing the widget
No longer works. I guess it's a security feature?
So... I have found another widget that will take me to the menu screen in settings where I can turn on or off.
The problem is that it doesn't always work 😕. It's a bit hit and miss.
I looked at and searched for others. Either they don't work or just poor usability.
Any recommendations?
In 9 (or maybe earlier), you can pull down from the top (quick setting toggles), then pull again to get the expanded grid, then hit the little pencil at the bottom to re-arrange the toggles. Hold airplane mode and drag it into the top 6 so it will show up in the list of "quick toggles".
I see your new member, like to say welcome!
Ashok Dharshan
