Just a better battery saver (Jabbs)
Tired of tools, killing apps in the background or change the system configuration, you never want?
- Jabbs is the first battery saving tool which handles the data and airplane control in Lollipop and never change your system configuration!
- All features with one click, easy to use.
- Jabbs the best radiation protection tool in the market, free and without any advertisement. Try it out...
- Handle radio, data, Bluetooth, airplane,
automatic Wi-Fi toggle, radiation protection.
Pro features will come...
System requirement:
- Android 4.0+
- Sim Card
- Latest Android versions may need root (optimal)
Download in Play Store:
https://forums.androidcentral.com/e...ails?id=de.justchris.jabbs.pro&token=4_1IKr2-
Feedback are welcome.
