1. mrg666's Avatar
    The new Maps version 5.8 is causing too much battery drain while just waiting in the background (no GPS was not open). I went back to version 5.7 and battery use is normal again. Is there anyone else having this problem?
    07-28-2011 11:02 AM
  2. jdhuntington's Avatar
    I've seen sudden degraded performance with my battery over the last 2 or 3 days. It seems to correlate with a recent update to Google maps, though I can't be certain.
    07-28-2011 01:21 PM
  3. macman4's Avatar
    Me to. mrg666, how did you turn the update back to 5.7
    07-28-2011 01:46 PM
  4. mrg666's Avatar
    First uninstalled Maps 5.8. Then, I have downloaded the Harmonia patch on this page (see the second post). If you open the zip package, you can find the file Maps.apk in /system/app directory. I copied that file on the SD card and installed with a file manager.
    07-28-2011 08:54 PM
  5. mrg666's Avatar
    I have finally reinstalled ATK just to avoid battery drain with Maps 5.8.
    08-01-2011 08:38 PM
