1. timbomcchoi's Avatar
    I'm downloaded an equalizer app from Smart Android App (https://play.google.com/store/apps/details?id=com.smartandroidapps.equalizer) a couple days ago, and it says that it's using 20% of my battery....is this normal....?
    06-21-2012 04:09 AM
  2. Devinator's Avatar
    That sounds like a lot of battery usage for any app.
    I can't get to the link from where I am, I assume it is an audio control app? If so, how much music do you listen to? All day long? If so, maybe that's right, but, I dunno, still seems like a lot for what it does.
    06-21-2012 07:58 AM
