1. pcguys's Avatar
    This might be related to installing Lookout last night, but I notice that my kernel is consuming 4.7% batter, followed by android system at 4.1%.
    gSam Battery Montior shows Android System held awake for 6 minutes in last 3 hours. The next biggest is gmail at 2 minutes.
    I notice that Lookout is listed as an "ongoing" process in my pull down notification.
    I think I'll uninstall Lookout and screen shot some base lines, but I figured I'd ask if this sounds normal?
    Do antivirus apps drain battery, or does it only scan on newly installed apps?
    Any thoughts?
    (I'll ask a separate question about AV in a separate thread).
    Thanks,
    Mike
    07-18-2012 10:42 AM
  2. TheAssailant's Avatar
    Lookout will occasionally scan every app along with the regular new app installs. Together, those would cause battery usage to increase.
    Sent from my VZW Galaxy Nexus using Android Central Forums
    07-18-2012 10:46 AM
  3. pcguys's Avatar
    BTW, I should have mention I'm rocking the new Galaxy S3 on ATT.
    Mike
    07-18-2012 11:03 AM
