1. pcguys's Avatar
    I can't seem to figure it out
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
    07-29-2012 10:56 AM
  2. funkylogik's Avatar
    long press screen, scroll icons at bottom to the left, tap "short cut" (2nd from the end) tap "settings shortcut", tap battery
    07-29-2012 01:24 PM
  3. pcguys's Avatar
    Thx, I was able to shortcut settings but not battery directly. Am I missing something?
    07-29-2012 03:49 PM
  4. funkylogik's Avatar
    when u tap "settings shortcut" it should take u to another list of parts of the settings with "battery" in it. im using european s3 though
    07-29-2012 04:56 PM
  5. pcguys's Avatar
    yes, that's exactly what I'm trying to avoid.
    Call me lazy, but I don't want to click a setting shortcut, then have to scroll down to battery to click that,
    any way around having to do that?
    07-29-2012 09:27 PM
  6. funkylogik's Avatar
    thats what i mean. when ur settin up the shortcut theres a direct shortcut to battery within the settings shortcut that puts a green battery icon on ur screen. maybe its just on international
    07-30-2012 07:40 AM
  7. pcguys's Avatar
    I ended up reinstalling gsam battery monitor. Originally,I didn't want a widget chewing up battery. This time I only created a shortcut to it so one press tells me the battery level.
    Problem solved.
    Sent from my iPad using Tapatalk HD
    08-01-2012 06:39 PM
  8. funkylogik's Avatar
    cool man. guess it must just be the international that gives battery shortcut. can i recomend Battery Notifier. check it out man its free and much better than the standard battery percentage in status bar
    08-02-2012 09:24 AM
