ellisz
I have noticed an incredible battery drain as well. Not sure if it is BW or not but it is crazy fast. I hope the update fixes it ...
What fixed all issues for me was : Uninstall BW, restart device, reinstall BW and set it up. It all worked perfectly then. Still I think this widget has some serious battery drainage.
I'm not totally convinced this widget is updating at my 30min but its seems to be working ok.
@erminal33 are you running a live wallpaper? those will always lag to some degree vs. static images
Working prefectly well here. If your time or weather are not updating, you are using a task killer. Lose the TK.
New update has added refresh on unlock, so you can save the battery and only get updates when you need them. Awesome!
I'm not so worried about the temperature being off a few degrees. If it's hot out, it's hot out. The time matches, so that's good. What is really urking me is the fact that the Geolocation feature is not working. I live in an area where there are many small towns and cities around me and it seems to find all of them and where I am, but it keeps cycling through them at random. If I'm where I live it should say that town, if I go to the next town, it should reflect that. The developer said I'm experiencing the limitations of geolocation. I guess I just need to send an email to Google about a refund and then look for something else that maybe will do what it's supposed to do.
