1. ob1droid's Avatar
    Just got an ATT Captivate. LP does not show in the Applications. I can find it on the Setup/Applications menu but, of course, can't run it. Is there something I'm missing? I'm not running any new "home" apps.
    Thanks
    08-08-2010 11:39 AM
  2. dmnall's Avatar
    When installed the phone should bring up a menu when you click on the home button and ask for twlauncher or launcher pro! Just click on launcher pro on your phone to run it! The last version I had problems running it on my captivate because it would lock up!
    HTH,
    Charlie
    Sent from my SAMSUNG-SGH-I897 using Tapatalk
    08-08-2010 11:43 AM
  3. moosc's Avatar
    Also LPP is not in the app drawer.
    08-08-2010 11:55 AM
  4. Kage_'s Avatar
    If you having issues getting LP to activate grap the app Home Switcher. I will allow you to change the default launcher that is being used. I think some vendors are intentionally disabling the flag that allows users to change launchers.
    08-09-2010 11:36 AM
