1. benitto's Avatar
    Max Battery Booster is the best energy saver.
    This app can be combined with other energy saving apps because it does another type of optimization. This app optimizes the work of the device.
    This app makes the cpu skip unnecessary calculations.
    Without reduction of display brightness, without wi-fi reduction and without any reductions. Easy energy saving with the free android app Max Battery Booster:
    07-10-2013 10:33 AM
  2. androidfan1x's Avatar
    You don't even explain how it works on
    Play store Description.
    So how exactly does it work Without reducing brightness, CPU power, turning off wifi,....
    I don't get what "makes the cpu skip unnecessary calculations" means
    07-10-2013 11:30 AM
  1. Replies: 116
    Last Post: 08-17-2016, 09:32 AM
  2. Replies: 4
    Last Post: 09-15-2013, 06:02 AM
  3. Outlook.com Push on the Stock App?
    By bgl321 in forum Samsung Galaxy S4
    Last Post: 07-30-2013, 01:30 PM
  4. Should I buy a Samsung Galaxy S3 or buy the S4?
    By marcher22 in forum Samsung Galaxy S4
    Last Post: 07-10-2013, 05:31 PM
  5. Is the S4 car charger same as Samsung Galaxy Ace?
    By acsurfer in forum Samsung Galaxy S4
    Last Post: 07-10-2013, 10:36 AM
