1. sandman512's Avatar
    Yes, I searched but I was over whelmed. With that being said, looking for a recommendation for a Battery Monitor that can go in the status bar and give me a Numerical readout. Thanks much!
    10-08-2010 10:07 AM
  2. IIJBII's Avatar
    Sandman512 - There are a lot of battery indicators on the market, but, the one I like and use is "Battery Indicator Pro". It can stay in your status bar and it sounds like this is what you are looking for. I think it may be .99 or something like that in the market, but in my opinion its well worth it.
    sandman512 likes this.
    10-08-2010 10:21 AM
  3. sandman512's Avatar
    Thanks much, I'll look into it. Now, if just find a notification app.
    10-08-2010 10:25 AM
  4. IAmSixNine's Avatar
    I use BatteryTime.
    I actually upgraded to the paid version i like it so much. It gives you multiple widgets, but more importantly it allows you to set a notification if it drops below a certain percentage. It also has an option to be put in the top menu bar.
    10-08-2010 11:38 AM
