1. Snareman's Avatar
    Just started using the Launcher Pro plus Facebook widget. Anyone know how much battery it sucks away? Does it poll FB pretty frequently? Is there a way to close it so it doesn't keep checking?
    12-04-2010 06:23 PM
  2. droidxixis's Avatar
    you can change how often it checks for updates in the preferences section. Anywhere from 5 mins up to 24 hours, or manually. So i guess manually is what you're looking for, so you can just update it when you want to.
    Snareman likes this.
    12-04-2010 11:45 PM
  3. terpitude71's Avatar
    i have mine update every 15 minutes, and it has a minuscule effect on my battery life
    12-05-2010 12:03 AM
  4. Snareman's Avatar
    Found it thanks!
    12-05-2010 01:11 AM
  5. juggalofx's Avatar
    I am a pretty heavy user and I have not noticed even a little drop in battery life with it. I have mine set to refresh every thirty min.
    Sent from my DROIDX using Tapatalk
    12-05-2010 02:02 AM
