Hello androidcentral,
I am having a problem with my "DOOGEE DG800 VALENCIA", on fully charged battery I can pull away max round 24hrs of idle and semi-active use, and the battery useage says that the phone is drained by the "phone idle" thing.
So far I tried the folllowing :
-got new battery
-changed from "kitkat" to "lolipop"
-formated the phone, cleaned the cache
-and a lot more ...
non of the above helped out, so what do I do ? any ideas, any solutions (just dont tell me to install monitoring apps, couse I tried that, and aint helpful), any1 had a simillar problem ?
Thanks a lot, here's a SS of the battery stats.
-got new battery
-and a lot more ...
