1. marcolarco52's Avatar
    So I recently realized that snapchat is using like 10 times the data it used to use and alot more battery drain with it even on my sony z3 having the power saving mode active that it only runs when the screen is on. I did downgrade it to 8.1.2 but then got the error that I'm using an older version and I had to update in order to log in.
    Running stock android 4.4.4 (never updated to the newest system as I did not want to)
    Thanks
    EDIT: I should mention I am in no way wanting to root my device or anything of that kind.
    07-16-2015 02:50 PM
  2. Russell BELL1's Avatar
    I've noticed this too, I don't know about data, but I assume thats because it loads all the videos without you actually having to open them, but the battery I've noticed as well. I think thats because of the new feature called snapcode, that uses GPS to locate snapchatters near you.
    07-16-2015 03:04 PM
  3. marcolarco52's Avatar
    I know the discover videos are all auto loaded now (the paid advertisements on top in your story section)...which is crap this app has gone down the toilet considering just deleting my account and moving on.
    07-16-2015 03:20 PM
  4. razza1987's Avatar
    Wow I didn't know that everything was autoloaded on snapchat. That would explain why I go through my internet so fast...
    07-19-2015 05:18 PM
  1. New game: keep taking and nobody explodes
    By goin_nil in forum VR Headsets
    Last Post: 03-21-2016, 09:47 PM
  2. Severe Battery drain with everything disabled
    By Connort226 in forum Samsung Galaxy S4
    Last Post: 07-30-2015, 05:23 PM
  3. Replies: 1
    Last Post: 07-16-2015, 11:26 PM
  4. Replies: 0
    Last Post: 07-16-2015, 02:32 PM
