1. Bryan Douglass's Avatar
    Recently installed Opera Max on my OnePlus One as part of the Moto X contest offered by AC... loved the idea and have seen positive returns on the "investment".
    However, I've recently noted diminished battery life during the day. Without significant change to daily routines, I started tracking app usage reports via the Battery menu in settings and consistently find Opera Max listed atop this list (using more power than the screen). It's become an internal debate each day as I attempt to weigh benefit versus expense for the app... and I'm wondering if I'm alone.
    Are you seeing similar issues? If the answer is "yes", what are you doing in response? Regardless of the answer, do you have advice, guidance or recommendation for positive resolution in this situation?
    Thanks in advance for your time and consideration!!!
    10-22-2015 11:32 AM
  1. Will battery packs become irrelevant soon?
    By j j6 in forum General News & Discussion
    Last Post: 11-07-2015, 10:29 PM
  2. Replies: 2
    Last Post: 10-22-2015, 02:37 PM
  3. Why is Android OS using 64% of my battery
    Last Post: 10-22-2015, 01:11 PM
  4. Replies: 1
    Last Post: 10-22-2015, 12:53 PM
  5. Ordering a non-manufacturer's battery for my smartphone..is it safe?
    By AC Question in forum Samsung Galaxy Note 3
    Last Post: 10-22-2015, 07:39 AM
