Light flow not longer works
Dan Newton
I just received my replacement LG G4. I installed my light flow application. Ever since the application was installed it has not worked. I have gone through the settings several times everything looks good. I uninstalled the app and install again. Still the same issues. Any suggestions?
If the replacement G4 has the newer firmware, then perhaps light flow is not compatible with it. Contact the developer of lightflow, they'll probable have an answer for you. You can reach them usually through and "about" icon within the app settings, or search the app in the app store, and scroll down to bottom and usually there's a contact icon.
Chris
shawnjosecrespo
