1. Uttam Kumar Khadka's Avatar
    I have installed gsam battery monitor pro and at the bottom there is a info " average per complete charge" and battery life , screen on ... actualy what they represent ? Is it the time my device screen can be on ? And what is in the bracket? Please reply
    Thanks
    ( screen shot attached )
    Attached Thumbnails About Gsam battery monitor-tmp_16184-screenshot_2016-08-27-15-46-02-1635884922.png
    08-27-2016 06:11 AM
  2. B. Diddy's Avatar
    The average is computed from your past usage. I believe it extrapolates the total battery life that you would've had if you used the phone down to 0% (as well as the screen-on time), and averages this over time. The "Max" time for the screen might refer to how much time the screen was on maximum brightness.
    08-28-2016 12:05 AM
  1. Nexus 10 Tablet - dead battery
    Last Post: 08-28-2016, 06:48 AM
  2. Replies: 3
    Last Post: 08-27-2016, 10:41 AM
  3. Cell Standby drains battery when I have no sim inserted.
    Last Post: 08-27-2016, 07:02 AM
  4. App that ONLY shows Digits or BIG Battery icon when charging
    By ilordvader in forum Samsung Galaxy Note 7
    Last Post: 08-27-2016, 05:05 AM
