1. AtulSharma's Avatar
    Suddenly few days ago, my yu yureka battery started draining and heating up giving strong burning sensation at the top left side.
    When I searched a bit then I found mediaserver app was eating a lot of battery.
    I searched a lot and did a few things
    1. Disabled mediaserver app
    2. Disabled most of my apps to save more battery
    3. Disabled some more settings to conserve even more battery
    It seemed that the problem was resolved but after few days it started again and again mediaserver was seen as the largest battery consumer upto 70%.
    I checked the disabled app list but it was not visible there neither was it visible in the running app list. It was nowhere except the battery drain list.
    I tried to disable some more apps but no use. Its eating battery like anything.
    Guys please help.
    09-27-2017 01:49 PM
  2. anon(238680)'s Avatar
    Welcome to Android Central. You might look here:
    Fix Mediaserver Battery drain and Over-heating problem in Android
    09-27-2017 02:01 PM
  1. Sandisk 3.0 USB to Micro
    By Rick Wieferich in forum Samsung Galaxy Note 8
    Last Post: 09-28-2017, 01:19 PM
  2. Google Play Services hammering the battery
    By ballstitch in forum Samsung Galaxy Note 8
    Last Post: 09-27-2017, 08:52 PM
  3. What is the next big phone from Samsung going to be?
    Last Post: 09-27-2017, 01:46 PM
  4. To switch from GSM to CDMA
    By samuelowusuessien in forum LG G Flex Rooting, ROMs, & Hacks
    Last Post: 09-27-2017, 01:39 PM
  5. Unable to view all emails - Samsung galaxy s5
    By cascamfc in forum Ask a Question
    Last Post: 09-27-2017, 06:41 AM
