How did you get it to work? Mine only connects the mirrorlink
Mine also only connects to Mirror link. Tried forcing it to use android auto but still no joy.How did you get it to work? Mine only connects the mirrorlink
That's pretty much what I get with my Skoda octavia too. It seems to be some combination of apps which conflict with AA, but haven't been able to pin down which ones.
Have a G4 as well. (UK Vodafone) I went back to factory reset and android auto worked a better (still some failures to connect) but after installing all my apps. It progressively got worse and worse.What phone model do you have? I'm still trying to figure out if it's more of a phone or car maker issue. I tried using a Galaxy S5 (took me a factory reset to make it work) and a Nexus 7 2012 and both work, but I am not yet 100% sure it is the G4 specifically.
Try a different cable too. Sometimes that makes a difference.
