I just bought a Hyundai Sonata 2015 and I'm amazed by Android Auto and it's functionality. I did notice that on a 30 minute car trip using maps, gps and playing google play music with Android Auto, my phone went from 40% to 34%. The phone says it's charging, but the car's USB port is not giving enough voltage to actually charge it while using android auto.
I have a USB Y cable that I tried plugging one end into a cigarette lighter adapter and the other into the usb port of the car and that showed it was charging the phone, but the phone still lost charge on my way home.
My note 4 struggles with battery life as is, so this will be a huge problem if I want to use android auto on a long trip and keep my phone charged. Does anyone have a solution for this problem, or am I stuck having to unplug android auto to charge if the phone is about to die?
EDIT: I just purchased a usb y cable that is micro usb to two usb's on Amazon. The one I was using in my post was a female usb to two usb's. Maybe a direct connection into the phone instead of a cable chain will provide adequate power from the cigarette adapter. I'll report back if this does work in case someone else has a similar problem.
