1. ultimachaser's Avatar
    I just want to know if using the maps on android auto will use my Data
    01-11-2016 09:19 AM
  2. Phil Nickinson's Avatar
    Sure. Maps is maps.
    01-11-2016 09:21 AM
  3. ultimachaser's Avatar
    thanks, I wasn't sure if it was a version that downloads the maps like a few other navigation apps, instead of constantly updating them.
    01-11-2016 09:41 AM
  4. DLCPhototography's Avatar
    Google Maps does give you an option to download maps for a given area to your phone, which theoretically would avoid data use while you're driving. At the same time, though, I'm not certain it will default to using the stored data, instead of getting current data online, when it does have access to a data signal. It's possible you'd need to turn off Mobile Data in order to have it use the stored data. And you'll need to keep your data on, I believe, or Android Auto in general won't work.
    Also, the stored data is automatically deleted after 30 days, so you'd need to keep on top of this.
    Just a few thoughts for you to consider, if you need to tightly manage your data usage.
    01-11-2016 06:56 PM
  5. Dixie Burge's Avatar
    This is what I have been doing: I put in a route on Android Auto, and when navigation starts, I leave AA on my phone and turn off data. The navigation will continue on the car's screen without the phone's data being on until the route is complete. Almost no data used! Of course, if I want to set a new route, data must be turned on on my phone again.
    Ntchwaidumela likes this.
    01-22-2017 12:35 AM
  6. DLCPhototography's Avatar
    Good to know, as this will come in handy when traveling internationally, where I still need navigation, but don't want to chew up data!
    One downside in general is that without data, you will lose Google's ability to route relative to existing traffic. Depending on where you are, that might or might not be an issue.
    01-31-2017 07:42 AM
  7. anon(871934)'s Avatar
    For international travel why not just use the HERE WeGo app with offline maps? Then you can still get traffic but with offline maps.
    01-31-2017 04:37 PM
  8. DLCPhototography's Avatar
    I hadn't come across that App before. Looks like an interesting option.
    But if it's getting traffic, I assume it's going to need a live data connection. Not as data hungry as maps, I would think but still.
    My next trip is Iceland, though, so I don't think I'll be needing traffic data in any case!
    01-31-2017 04:47 PM
  9. anon(871934)'s Avatar
    I've read a few articles that suggest that HERE will use about 1.0 - 1.5 mb per hour if left online. Within the app you can turn the data usage off completely. You could turn it on selectively if in a larger metro or during higher traffic periods.
    01-31-2017 05:02 PM
  10. nicosilber's Avatar
    Hello in my experience I was not able to search addresses in my AA while offline. I need to be online to search for address and then I was able to navigate without any problem. But with downloaded offline maps it's impossible to search for an address. In mt tablet with downloaded/offline maps I am table to search any address (if its inside the area I downloaded). But once I plug my phone (in airplane mode) to my car and google auto starts it wont find any adress even if that address was inside a downloaded map. Please help
    07-10-2017 07:32 PM
  11. Peter Nowell's Avatar
    Enable data and set your destination and the location or GPS will take over. Then disable data and let the GPS or location use the satellite to direct you. Do not keep your data on once the satellite is connected to your phone's GPS.
    10-06-2017 02:50 PM
  1. Replies: 1
    Last Post: 01-11-2016, 10:56 AM
  2. Replies: 2
    Last Post: 01-11-2016, 10:28 AM
  3. Replies: 2
    Last Post: 01-11-2016, 10:01 AM
  4. Replies: 1
    Last Post: 01-11-2016, 09:03 AM
  5. Replies: 0
    Last Post: 01-11-2016, 08:47 AM
