Originally Posted by
Rukbat Are you running Android Auto (Maps running on the car head unit)? If so, run Maps on the phone and listen to the phone. The sync should be close enough that you'll be making all the right turns at the right times. (Even Magellan and Maps sync pretty closely, and they're totally different software.)
That's, uh, not really going to work. (And means more messing with your phone in the car, which is exactly what we *don't* want to happen here.)
Best advice in this case is to just mute the voice guidance, like the good uncle said above.
