it was good if you are facing issue Your car needs to be compatible with Android Auto or have an aftermarket unit installed. Android Auto won't work on all cars equipped with a USB port. See this list for compatible cars and to find manufacturers of compatible aftermarket head units
Not all USB cables will work with all cars. If you're having trouble connecting to Android Auto try using a new USB cable.
If your Android Auto app used to work and no longer does, try these troubleshooting tips:
Check your Android phone. You might need to install some updates before you can keep using Android Auto. Check Google Play for updates and learn how to update your apps .
If all your apps seem to be updated, unplug your phone and try turning it off and back on before connecting it again.
