1. ex-28's Avatar
    i know the deck has a good eq built in but when driving at times it would be great to have treble control at my fingertips from time to time .
    so im looking at installing Clarion EQS755 equalizer.
    problem is how would you connect this ?
    the eq has
    main in and aux in
    so from my deck what line would i use to go to the main in on the eq
    front pre outs or
    rear pre outs
    sub pre outs
    my setup i have 2 amps , 1, 4 channel amp for my fronts and rears
    1,mono amp for the sub
    off my deck now i am useing front,rear rca preouts to the 4 channel amp
    and the sub out for my mono amp
    so i just connect the front out rca off the hu to the eq input
    then run the 2 sets of rca to my 4 channel amp , front out and rear out. and leave the rear preouts disconnected on the back of the hu deck correct ?
    also hoping i could make use of the sub volume on the eq and do away with my inline sub volume knob
    would this be possible ?
    01-31-2017 08:16 AM
  2. scott_0's Avatar
    yeah, you would use the front rca out of the headunit to the main in of the eq, it splits it up for you into the Fr, Rr, and SW
    ex-28 likes this.
    01-31-2017 01:26 PM
  3. ex-28's Avatar
    so for the sub volume knob on the eq would i run sub out from hu to aux in on the eq ?
    01-31-2017 06:24 PM
  4. scott_0's Avatar
    no, you simply run the sub out to your subwoofer amp, the eq will split up the input signal
    02-01-2017 03:32 PM
  5. ex-28's Avatar
    ahh ok so the only output from my hu i use is the front outs to the eq ?
    leaving rear out and sub out rca disconnected. on back of hu
    02-02-2017 08:21 AM
  6. scott_0's Avatar
    yes the eq only needs the main input, it will do the splitting up within, therefore giving you control through the eq
    ex-28 likes this.
    02-02-2017 11:41 AM
  7. ex-28's Avatar
    ok thanks , guess for some reason im thinking i wont get as much base output useing front out from hu to the eq
    as i would useing sub out from the hu direct to my sub amp.
    but i do want to make use of the base volume knob on the eq.
    02-06-2017 08:18 AM
  8. scott_0's Avatar
    well, you won't have less output with the bass, but imo the built in eq of the headunit is better and what I would use personally, if it's bass volume adjustment you are after, I'd add a bass control knob and ditch that eq........
    02-06-2017 08:33 AM
  9. ex-28's Avatar
    ya understand totally , buyt with the eq connected my only question now is do i leave the low pass frequency set to 60hz or 90hz on the eq as per image above
    02-06-2017 08:02 PM
  1. Replies: 2
    Last Post: 01-31-2017, 12:11 PM
  2. Replies: 3
    Last Post: 01-31-2017, 07:41 AM
  3. Replies: 0
    Last Post: 01-31-2017, 04:01 AM
  4. Replies: 3
    Last Post: 01-31-2017, 03:36 AM
  5. Replies: 0
    Last Post: 01-31-2017, 12:58 AM
