1. leunam12's Avatar
    Android Auto takes control of my phone after I disconnect it from the car; it is very annoying, it doesn't let me do anything and I don't know how to stop it. I press home and my home screen shows for a few seconds, but then Android Auto pops up again.
    Any help? Thanks
    05-19-2017 04:48 AM
  2. andrew.harris's Avatar
    Sounds like you've got Auto Launch on BT connect on in settings. That's for when you want to run it on your phone, not the car screen.
    05-19-2017 04:56 AM
  3. leunam12's Avatar
    Interesting, should I go to Settings>Connections>Bluetooth and look for auto launch? Let me try that. thanks
    05-19-2017 06:26 AM
  4. leunam12's Avatar
    Ok, I found it, it was in the AA settings, I disabled it, Let's see what happens. Thanks
    05-19-2017 06:40 AM
  1. How do i get past the Samsung account lock?
    Last Post: 05-19-2017, 05:53 AM
  2. My LG xpower phone has got stuck showing Firware update.
    Last Post: 05-19-2017, 04:48 AM
  3. Blue Diamond floating on my screen
    Last Post: 05-19-2017, 04:45 AM
  4. Battery seems to drain quickly on s8 plus when using it?
    Last Post: 05-19-2017, 04:31 AM
  5. How i recovery of photos or files in audio manager
    Last Post: 05-19-2017, 04:21 AM
