Android Auto- connection issue
  • Start date Start date
A
AC Question
My mobile phone is updated to android-7.0.
After update, Android auto is not getting connected on the car's AVN system.
App is running on mobile, but not getting projected on Car display. Android Auto App Version on mobile is- 2.4.722903.
When the USB is connected, Android auto icon does not show up on car display. Even after launching the app on mobile, it doesn't get projected on car display, the way it used to be. Mobile is getting charged but not showing option to select MTP.
However another mobile with AA Version- 2.4.722904 running on android 5.1.1 is getting connected with the same USB cable. It launches automatically as soon as the USB is connected.
Tried selecting MTP under developer options. No change in connection.
Pls help.
dooleysdickulove
