Recently, I have been experiencing some serious connectivity issues while using AA on my Galaxy Note8 connected via USB to my 2016 Honda Accord compatible head unit. I can connect to the head unit and launch AA however, and for an unknown reason, it suddenly loses connection. I have to unplug and plug back in the USB a few times for it to reconnect. After connecting, a few minutes pass and the connection fails.
I purchased a new USB cable thinking that may have been the issue but it didn't fix it. I then had AA forget all cars and reconfigured it, that didn't work. I then completely removed AA and reinstalled it again, completing a fresh setup, no luck there either. I thought maybe my car USB port was malfunctioning however, I had it looked at by Honda and it is fine.
I've also activated Developer Options/USB Debugging with no impact on my experience.
I should note that, prior to upgrading to the Note8, I used a Galaxy S7Edge with absolutely no connectivity issues.
Does anyone in the community have any suggestions? I've exhausted everything I can think of. Many thanks in advance. I love AA and the ability to have it on my car's displays.
