1. tony bag o donuts's Avatar
    So I'm using pie on an axon 7.
    Android auto used to work perfectly via USB to the Honda's infotainment system. Android auto launches and I can play music, use maps, phone calls, etc.
    However, recently when using maps there is no voice guidance. All settings seem to be correct. Even when a turn is coming up the music gets lower and there isn't any voice coming through. If I use Android auto on my phone via Bluetooth, no issues with turn by turn navigation.
    I have unpaired the devices and just factory reset the Honda head unit.
    Should I reset my phone? Last resort but I am at my wits end.
    Please provide any advice. Thanks.
    01-23-2019 07:54 AM
  2. Rukbat's Avatar
    Uninstall Maps. Reinstall Maps. Less of a problem that a factory reset. It may help, it may not, but it just takes a minute.
    01-23-2019 11:43 AM
  1. why is my phon shutting down suddenly?
    By mohammad pak in forum Ask a Question
    Last Post: 01-22-2019, 06:17 PM
  2. "coral backup" after factory reset problems
    By Joshmosh98 in forum Ask a Question
    Last Post: 01-22-2019, 01:08 PM
  3. My charger suddenly won't go into my s8 charging port. What do I do?
    Last Post: 01-22-2019, 12:42 PM
