1. Guru's Avatar
    I posted this in the S10 forum but no responses so let's try in here. Anyone else hook up their s10 for android auto and use Waze? I even set the manual setting in the Waze app to night mode and STILL bright as the sun white background. Any help would be appreciated. Old Samsung j3 did not ha e the issue nor my old cheap Indian no name phone.p
    03-09-2019 12:18 PM
  2. Guru's Avatar
    NM folks you can close this thread. Figured it out. Had to reboot.
    Nostromo79 likes this.
    03-09-2019 04:58 PM
  3. nyc_rock's Avatar
    Reboot what? I have the same problem with my S10+ except I'm stuck on night mode.
    06-03-2019 05:32 AM
  4. Yorimayo's Avatar
    I have samsung S9 and have the same problem, no night mode in waze neither google maps. I hope they fix this soon.
    07-19-2019 11:01 AM
  5. BarracudaBob's Avatar
    My S8+ has the same problem with Waze not going to night mode with Android Auto ever since I started using the new layout for Android Auto. The app on the phone does display night mode as expected though. My phone reboots every weekend and the problem has not gone away after several reboots.
    09-16-2019 03:19 PM
  6. BarracudaBob's Avatar
    I found a solution so I figured I'd share it here.
    Open Android Auto and go to Settings
    Scroll down to the Version and permission info
    Click on it repeatedly until it enables Development mode
    Use the hamburger menu in Settings to go to Developer Settings
    In Day/Night mode, select either Phone controlled or Night (depending on your preference)
    Now when you connect your phone to the car via USB it will use night mode in Waze or Maps as selected.
    12-20-2019 10:42 AM
  1. how to retrieve saved call recordings from automatic call recorder in redmi 5
    Last Post: 04-06-2019, 05:51 AM
  2. Unable to get Google Assistant or Bixby to answer from Car Audio
    By NIZMOZ44 in forum Samsung Galaxy S10 & S10+
    Last Post: 03-11-2019, 07:26 AM
  3. New Charger Lead Not Working With Android Auto
    Last Post: 03-09-2019, 01:12 PM
  4. usb to hdmi cable
    Last Post: 03-09-2019, 01:11 PM
  5. My Samsung Galaxy tablet 3 is not connecting to wifi
    Last Post: 03-09-2019, 12:48 PM
