Android Auto random volume changes and chimes
Greetings,
Samsung J7 Prime - SM-J72711
Android 8.1.0
Baseband - J727T1UVS5BSC2
Kernal - 3.18.14-14133265-QB22566678
Build - M1AJQ.J727T1UVS5BSC2
Ford Sync 3
Problem #1 - Volume goes up and down while streaming music (Amazon, iHeart).
It's similar to when Waze lowers the volume to deliver a message.
I tried the following:
Uninstalled Waze, still happens.
Disabled all app notifications, still happens.
If I bypass AA and stream via bluetooth the volume does not change.
Problem #2 - Chimes while speaking on phone.
Just loud enough to be annoying. It's a 5 note chime. Happens at random intervals only while speaking on the phone.
I have tried the following:
Bypass AA and speak via bluetooth, no chimes.
I have also uninstalled and reinstalled AA to no avail.
The former has been happening for months, the later is a new issue.
I have searched and searched for solutions, must not be common problems because I can find very little info these.
tia
Re: Android Auto random volume changes and chimes
I moved this from the Oreo forum to the Android Auto forum for more specific traffic.
Originally Posted by
B. Diddy I moved this from the Oreo forum to the Android Auto forum for more specific traffic.
Thank you, first time here :)
No problem, welcome to Android Central!
Well I restarted in Safe Mode thinking I would launch apps one at a time to try to see which ones are causing the issue.
Turns out Android will not allow me to launch downloaded apps while in Safe Mode.
They sure don't make it easy to track down issues.
Thx tsells.
Been 2-3 months for me :(
