1. tacky12's Avatar
    I have 3 problems with my LG Spirit (one is my fault, and the other one is normal. First, my battery drains real fast, and sometimes the phone gets a bit hot. If I use something like Real Racing 3 for one minute, the battery can drain from 100% to 96%. Then, the phone gets a bit hot. But, I think it could be because one day, I dropped it bottom-first on the floor from 4 feet. Second, I can't move apps to the SD Card. This is normal, as it can't be done in devices from android 4.0 and above. But I want to be able to move them to the SD Card WITHOUT rooting. And third, I get a problem where I can't update or install any small apps, because it says "insufficient storage available". So, I tried to fix by uninstalling the Play Store updates, but it didn't work either. And now, I'm stuck with the old Google Play. If I try to download an apk of the new one, my old buddy "Insufficient storage available" comes to greet me. I have over 2 gigs of storage, and I've cleared cache and data, and rebooted, but nothing works. Please help me with these problems. I'm frustrated.
    06-27-2013 03:55 AM
  2. Fairclough's Avatar
    I don't have your mobile but gaming makes mobiles HOT! Thing of a computer your phone has similar specs and no cooling fan. Something's gotta give.
    Posted via the mystical forest creatures that power this Nexus 4.
    06-27-2013 04:17 AM
  3. tacky12's Avatar
    Well, yes I know it gets hot, but what about the battery draining really fast? I have a Huawei Ascend Q too, and If I do the same things I do on the Spirit it lasts more. Even though my Spirit has a better battery.
    06-27-2013 11:31 AM
  1. default puk codes for AT&T LG-P925
    By scottiej61 in forum General Help and How To
    Last Post: 01-15-2015, 08:12 AM
  2. Adobe Flash Player for LG Optimus Showtime L86C
    By GisTisMe in forum LG Optimus Series
    Last Post: 06-21-2013, 03:06 PM
  3. Photos to LG tv
    By tat4bob in forum AT&T Galaxy S III
    Last Post: 06-21-2013, 01:04 PM
  4. Photos to LG tv
    Last Post: 06-21-2013, 12:42 PM
  5. LG F3...good cheap upgrade from OptiS?
    By On3wheels in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 06-19-2013, 01:07 AM
