1. AC Question's Avatar
    Just noticed alert for excessive data usage. It looks like Android OS background spiked but I only had it in the charger. Is there a fix?
    01-14-2016 10:35 PM
  2. yshysh's Avatar
    Open Settings / Data Usage to find out which app is using the data. Then either uninstall it or use Task manager to kill it
    01-14-2016 10:42 PM
  1. The 6p is hands down the best phone ever made!
    By getbretweir in forum Nexus 6P
    Last Post: 02-04-2016, 02:59 PM
  2. Replies: 1
    Last Post: 02-01-2016, 03:28 PM
  3. Do those battery saver apps really do their job?
    By yshysh in forum Android Apps
    Last Post: 01-15-2016, 06:13 AM
  4. Where is Clip board
    By Kevin Loving in forum Ask a Question
    Last Post: 01-14-2016, 10:31 PM
  5. Replies: 0
    Last Post: 01-14-2016, 10:27 PM
