    We are not able to use manual rotate and accessibility menu features together in Android 9 because once you enable the accessibility menu, rotate toggle stopped to getting appear at right corner of devices since accessibility toggle is present there.
    11-12-2018 01:13 PM
  2. Rugish Dapeca's Avatar
    I guess that is not something I personally would have discovered as I don't use the Accessibility Service. But you are correct that they both don't work at the same time.
    11-14-2018 03:25 AM
  3. Vipul Shirvalkar's Avatar
    Thank you for acknowledging to above my post. Can you please verify it once from your end and let me know if you found anything on this topic. Both features are fabulous and we are not able to use these only because of boths toggles are placed on right corner. So there should be option to move one toggle to left side. According to me, accessibility toggle should get move to left corner. Right side is a perfect place for rotate toggle.
    11-14-2018 12:59 PM
  1. Pie: How to receive app notifications without notification sound
    By Android Central Question in forum Google Pixel & Pixel XL
    Last Post: 07-24-2019, 11:30 AM
  2. S8 plus goes blank and after i reboot goes blank again
    Last Post: 11-12-2018, 06:56 PM
  3. Multiple updates - do I need to update previous ones or just current?
    Last Post: 11-12-2018, 06:01 PM
  4. Help transferring data to P20 Pro
    By LonestarROB in forum Huawei P20 & P20 Pro
    Last Post: 11-12-2018, 04:05 PM
  5. Save Android Wear Settings/Apps?
    By recDNA in forum Ask a Question
    Last Post: 11-12-2018, 12:57 PM
