Re: Why does my phone pause music and make a beep sound when I drive by the same spot?
I think that I figured it out. I believe this is my bixby routine turning on for my home routine. I'll investigate some more when driving by the same spot.
I used to have the same problem sometimes when driving past a small Air Force base. Any time the RADAR antenna was scanning the road, it would wipe out cell service. (Not FM radio - they had gotten complaints about that and fixed that problem.) Verizon put up a microcell right outside the gate to fix the problem.
But you might be correct - it could be something twling you that you're home, or switching from mobile data to your WiFi.
