1. skoenig's Avatar
    Lets see LIFX and Hue both in the range of $40-60 each... these are the next generation LED bulbs, free of the coolness/newness tax the premium lights seem to have...
    The QUBE Smartbulb is $19 each which is a bit higher than the early bird special reported earlier.
    Quick Specs
    • Material/Finish: Gunmetal Grey
    • Color Temperature: 2,500 K - 9,000 K
    • Dimensions: 2.47" D x 4.76" H
    • Brightness: up to 800 lumens (60W equivalent)
    • Dual Voltage: 110V ~ 130 V / 220~260V
    • Expected Lifespan: 50,000 hours. Up to 27 years based on 5 hours usage per day
    • Min Operating System (Setup): iOS 7 and above and Android 4.3 and above
    • Plug and Play
    • Fits with all E27, E26 Edison Screw Base and B22 Bayonet Cap
    • Qube works with and can be plugged into any electrical outlet AC 100-240V
    Obviously all manner of apps to go with it and control a group of them.
    Get em now before the perks run out.
    11-23-2015 01:38 PM
  2. skoenig's Avatar
    The early bird finished on this fellow so it now costs $19 per bulb, worldwide shipping is $3 per bulb which seems fair for small quantities.
    Looking through the comments they have mentioned adjusting shipping for large quantities as 100 bulbs would require $300 in shipping which doesn't seem right.
    I still feel this is a good deal as plain LEB bulbs run $7-$10 so for a little over double you can have a 'Smart' version which is so much more capable.
    12-03-2015 08:03 AM
  1. Why my Nexus 6 does not disconnect from wifi?
    By AC Question in forum Google Nexus 6
    Last Post: 11-23-2015, 02:37 PM
  2. Why can't my S6Edge+ access apps during a phone call unless on WiFi?
    By AC Question in forum Samsung Galaxy S6 edge+
    Last Post: 11-23-2015, 12:41 PM
  3. Why do I have a fast battery drain when wifi is turned on?
    Last Post: 11-23-2015, 11:50 AM
  4. Replies: 0
    Last Post: 11-23-2015, 11:07 AM
Tags for this Thread
