1. dedeandroid's Avatar
    Dear Sir,
    I bought two android tv box, the model are pendoo x10 and Turewell t9, both are not able to connect to my network.
    Thats beginning make me crazy. I want buy a android tv box with no network connections issues. Able to download apli. from the google play store , plex apli., amazon prime video apli. , netflix etc..
    Unless you have a solution to fix my issues. You are so kind if you can please suggest me a tv android box.
    Also I did attached two pictures The first one is the setup of my router
    The second one is my tv box setup . My question is why the ip adress and the mac adress is different then my router ?
    I dont know if i can change those adress in the tv BOX
    06-28-2020 06:40 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! I moved this to the Android TV forum for more specific traffic.
    06-28-2020 06:42 PM
  3. Galactic Zoo's Avatar
    Can the devices "see" the network?
    06-29-2020 03:13 AM
  4. Kizzy Catwoman's Avatar
    Can you connect them via ethernet cable? Or does it have to be by WiFi?
    Laura Knotek likes this.
    06-29-2020 05:41 AM
  5. dedeandroid's Avatar
    Yes i can see the network but when I try to connect to my network he reply to me cant find the network.
    This picture represent my network
    Attached Thumbnails Wi-Fi connection problems with my Android TV box.-prop-reseau2.jpg
    06-29-2020 10:45 AM
  6. dedeandroid's Avatar
    My configuration is Ethernet by cable as you will see in the attached pictures
    Attached Thumbnails Wi-Fi connection problems with my Android TV box.-prop-reseau.jpg
    06-29-2020 11:04 AM
  7. Galactic Zoo's Avatar
    If you disable security, does this make a difference?
    06-29-2020 01:28 PM
  8. dedeandroid's Avatar
    Hi, I disable the security and nothing change
    06-29-2020 04:23 PM
  9. Galactic Zoo's Avatar
    Hmm. Ok on the Android box, forget the wifi connection, reboot the router and try to set up again. Also, make sure in your router settings that it is not restricting connection to certain mac addresses
    06-30-2020 04:06 AM
  1. My AC mobile app keeps crashing.
    By joemontana57 in forum Android Central Apps
    Last Post: 06-28-2020, 09:58 PM
  2. My AC mobile app keeps crashing.
    By joemontana57 in forum Site Feedback & Help
  3. My AC mobile app keeps crashing.
    By joemontana57 in forum Ask a Question
    Last Post: 06-28-2020, 09:42 PM
  4. MAC address security in Android 10?
    By mellandroid in forum Samsung Galaxy A50
    Last Post: 06-28-2020, 08:55 PM
  5. Wi-Fi connection problems with my Android TV box.
    By dedeandroid in forum Ask a Question
    Last Post: 06-28-2020, 06:40 PM
