1. AC Question's Avatar
    I can navigate using a mouse but the remote just stopped working. The remote will work on another T95 box. Please send me the file I need to reload the remote. Thanks
    08-03-2016 04:02 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Moved to the Android TV forum. You might also want to try FreakTab, which has a more robust Android TV discussion: freaktab.com/forum/tv-player-support
    08-03-2016 04:16 PM
  3. Bandusix's Avatar
    Good third party remote for android tv and amazon fire tv, and I find the mouse can be use in this app called CetusPlay, you can find it on google play store
    and there is another on called wukong tv remote, but know it seems not working in the mouse.
    the remote for my T95 Android TV box stopped working, a mouse will work-1-lnmllobuiw05no4hxgqweq.jpeg
    08-17-2016 10:01 AM
  1. Just bought the Note 4 - Yeah, it's August 2016!
    By jiden77 in forum Samsung Galaxy Note 4
    Last Post: 08-07-2016, 04:29 PM
  2. I lost my All data when i connect with pc
    By Nowty Prince in forum Android 5.0 Lollipop
    Last Post: 08-06-2016, 03:00 AM
  3. Replies: 0
    Last Post: 08-03-2016, 03:52 PM
  4. How do I get my Contact Numbers back?
    Last Post: 08-03-2016, 01:33 PM
