1. SajetS's Avatar
    hello, i am the new one hier
    i bought an Android TV Box
    LPX-G BOX 2GB + 16GB Android 7.1
    SDRAM: 2GB DDR3
    Flash: 16GB EMMC Flash
    CPU: 64 Bits AmlogicS905X Quad-Core Cortex-A53@2.0GHz
    GPU: Penta-Core Mali-450 mit HDMI 2.0 Ausgang Kartenleser: TF-Karten
    i tried to flash another firmware for testing if it would work better than the original one.
    i downloaded an firmware from the Magicsee IRON TV Box because the specs looks similar.
    CPU – Amlogic S905X quad core ARM Cortex-A53 @ up to 2.0GHz
    GPU – penta-core Mali-450MP GPU @ 750 MHz
    SDRAM: 2GB DDR3
    The firmware works, but now i have the problem, that i could not connect the box to my computer, USB_Flash_Tool does not recognize the box anymore.
    What can i do to fix the problem?
    Before flashing i didn't have any problems mit the connection :-
    it seems like the reset button has no function anymore, thats why USB_Burning_Tool don't recognize the box
    i have no idea how to fix the problem.
    regards SajetS
    Attached Thumbnails LPX-G S905x problems with connection-image_28331.jpg   LPX-G S905x problems with connection-image_28330.jpg
    11-07-2017 04:51 AM
  2. SajetS's Avatar
    I think it's over now with the box... bootloop and no reset button funktion.
    no chance to do something
    SajetS
    11-08-2017 07:09 AM
  1. How to retrieve data from S3 mini with broken charger port
    Last Post: 11-08-2017, 01:28 AM
  2. Hi, I have a homtom ht16, with android6, it froze
    By hrmar in forum Ask a Question
    Last Post: 11-08-2017, 01:10 AM
  3. Replies: 1
    Last Post: 11-07-2017, 07:20 AM
  4. Moto g5s plus case with port hole covers??
    By Android Central Question in forum Moto G5S & G5S Plus
    Last Post: 11-07-2017, 03:36 AM
  5. Replies: 0
    Last Post: 11-06-2017, 10:16 PM
