    My interenet speed is 30 mbps until I turn on my H96 Pro+ Android Box and it's connected with ethernet cable and then it drops to 4 mbps for the whole network/all devices. The speed goes back up to 30 mbps when the Android box is powered off.
    Any help would be grately appreciated - Thanks
    07-26-2019 11:29 AM
  2. mustang7757's Avatar
    Hi , if you can register a account here , me or other members be happy to assist you .
    I'll provide a link to register so you can communicate here.
    https://forums.androidcentral.com/as...community.html
    07-26-2019 11:37 AM
  3. Haid's Avatar
    Any help would be greatly appreciated - Thanks
    07-26-2019 12:04 PM
  4. mustang7757's Avatar
    Hi thanks for registering!
    If you can stay in the thread you open to avoid duplicate post , I'll provide a link thanks
    [link not needed]
    07-26-2019 12:09 PM
  5. Haid's Avatar
    Hi - OK thanks
    mustang7757 likes this.
    07-26-2019 12:28 PM
  6. B. Diddy's Avatar
    Welcome to Android Central! To simplify things, I merged your duplicate threads.
    What's the brand and model of your router? Look at its manual to see how to log into its settings, and make sure QoS (Quality of Service) is turned off.
    07-26-2019 01:08 PM
  7. videostorm's Avatar
    The box is probably just loading something which is using up your bandwidth. Close all the background apps and disable OS updates.
    Also make sure to close the browser app (not just background it). Some boxes have issues that allow the browser to keep streaming video ads in the background.
    07-31-2019 02:43 PM
  1. The Vibration on my phone is non-existent
    Last Post: 07-26-2019, 01:43 PM
  2. How can I disable the white dot on my phone screen?
    Last Post: 07-26-2019, 01:17 PM
  3. Have tried all ways to open my phone and still google locked out
    Last Post: 07-26-2019, 01:04 PM
  4. Free android phone management software 2019
