Hi all,
MY TV keeps having this stupid bug.
If I try to customize channels, it basically refreshes the menu and does not do it.
Although annoying, I can live with it.
The problem is that this happens even when I’m not customizing any channels.
I’m just looking at the apps I have and… bum, the TV decides to refresh the menu and I am at the TV initial page.
I change the source to an HDMI input (like PLaystation) and, around one minute after, … bam, back at the initial android menu.
Only if inside an app it does not happen.
As you can imagine, this is terrible. I tried a factory reset – same thing!
I tried re-slashing the latest software – I can’t, since it is the same software already installed (it has to be a new one)
What can I do?
Any help is appreciated.
Even just your sympathy is appreciated…
Thank you so much in advance.
What can I do?
