    I am having issues turning my android box back on after turning off with my remote. I turned on the HDMI CEC settings to see if it actually takes the universal remote signal, but it does not help if the box is powered off. Seems like the problem is that it turns off after I put it to sleep with remote, and needs either a power cut or a physical switch to turn it back on (which these cheap knock-offs don't have). Is there a way to prevent it from shutting off after a while and just keep it at SLEEP MODE constantly.
    09-25-2019 01:41 PM
  2. mustang7757's Avatar
    Hi, welcome to Android Forums
    I'd like to recommend creating a account so me or other members can assist you, as guest have limitations in replying here and if we need further Information to communicate with you.
    I'll provide a link to register, please come back to your post so we can further assist you . Thank you
    https://forums.androidcentral.com/sh...d.php?t=409154
    09-25-2019 01:56 PM
  3. B. Diddy's Avatar
    I moved this to the Android TV forum for more specific traffic.
    09-26-2019 03:10 AM
  1. S pen remote problems
    By jrsharp70 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-27-2019, 05:58 PM
  2. Replies: 13
    Last Post: 09-26-2019, 01:45 PM
  3. How to turn of notification SOUNDS
    Last Post: 09-25-2019, 05:16 PM
  4. Urgent, Need Past notifications on a Note 8
    Last Post: 09-25-2019, 02:37 PM
  5. Why my facebook account only showinag about half pictures on my newsfeed
    Last Post: 09-25-2019, 12:11 PM
