1. Pogusone's Avatar
    Have an T95Max android TV box. Installed trend micro anti-virus, ran a scan that failed because the device is rooted. Is this a safe thing? If not, can it be unrooted and still function well?
    01-01-2020 12:03 PM
  2. mustang7757's Avatar
    Anytime you root it's risky .'ll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.https://forums.androidcentral.com/sh...d.php?t=409154
    01-01-2020 12:25 PM
  3. Pogusone's Avatar
    Have registered. Username is pogusone.
    01-01-2020 12:50 PM
  4. Pogusone's Avatar
    I have a T95Max android TV box. Installed trend micro antivirus on it. Ran a scan, which failed. One reason is because it is a rooted device. Am worried about security issues now. If I unroot the device, will it still function well? I use it to watch iptv.
    01-01-2020 01:00 PM
  5. mgbosshogg's Avatar
    If its just a TV box only ( as these should be), what does it matter?
    01-01-2020 01:08 PM
  6. mustang7757's Avatar
    Hi, welcome to AC forums!
    I'll see if mod can put in correct forum.
    01-01-2020 03:12 PM
  7. B. Diddy's Avatar
    I moved this to the Android TV forum.
    mustang7757 likes this.
    01-01-2020 03:32 PM
  8. B. Diddy's Avatar
    Duplicate threads merged.
    01-01-2020 03:35 PM
  9. Galactic Zoo's Avatar
    Some boxes are rooted, there's aren't. I would normally have security concerns but there's not really much of a risk if you use a different Google account to your main one. To unroot your only option is for the manufacturer to offer it
    01-02-2020 03:41 PM
  1. Good Lock doesn't work after Android 10 update.
    By corvette72778 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 01-03-2020, 04:46 AM
  2. Access save box LG Vista 2
    Last Post: 01-02-2020, 05:28 PM
  3. Why are videos sent from iphone to android When viewed are poor quality
    Last Post: 01-01-2020, 03:52 PM
  4. Issues with Gestures in Android 9
    By Chris Clayton1 in forum Android Pie
    Last Post: 12-31-2019, 04:12 PM
  5. Issues with Gestures in Android 9
    By Chris Clayton1 in forum Ask a Question
