Why is my data connection on TNT
  • Start date Start date
A
Android Central Question
Why is my data connection on TNT suddenly didn't appear anymore even if I already enable the mobile network connection, the sign above that you're already connected didn't appear.?
It may show up as Smart Communications. (It used to be called Talk 'N Text, then TNT.) If you have a data connection (say, you can see Android Central), it doesn't matter what notice you get about being connected - you are.
BrüZZi
