    I've been having battery issues with my Note 9 for awhile. I have tried clearing the cache partition, closing apps, putting them to sleep. I mainly use it for texting so it's not like I'm streaming tons of content and the battery is down to almost 50% by noon. It started doing this after an update in February. Just wondering if anyone has had similar issues or has any suggestions. The phone was bought new in January 2019. Thank you.
    05-09-2020 02:49 PM
  2. mustang7757's Avatar
    Try to monitor in safe mode , see if sane happens.
    I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.
    https://forums.androidcentral.com/sh...d.php?t=409154
    05-09-2020 02:51 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which may show Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    05-09-2020 02:54 PM
  1. NOTE 10 "Portrait mode" shooting of photos
    By eugchen in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 05-11-2020, 04:43 AM
  2. Pop up with: this language is not supported
    By kelin84 in forum General Help and How To
    Last Post: 05-09-2020, 10:18 AM
  3. LG V20 F800L Korean Variant LTE Network connectivity Issue
    Last Post: 05-09-2020, 09:52 AM
  4. What does the icon with a finger and three dots mean
    Last Post: 05-09-2020, 09:48 AM
  5. Edit Note in Screen Off Mode
    By objectLearner in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 05-09-2020, 09:06 AM
