    I know this is long I just want to give all the details so I can get an accurate answer. I turned on my phone (Nokia 3v) to use Google and a system update was downloading. When I tried to use google my keyboard wouldnt pop up. Turned my screen off to go sit somewhere to fix the issue then my power button wouldn't work! I didn't drop it from the time I turned the screen off to the time I tried to turn it on. I haven't dropped it in weeks. I plugged it in and the screen turned on and a message saying that the update couldn't be installed because the battery was under 50%. Keyboard finally works again but the on button and volume down don't. Again I don't think this is a physical issue. I did try to check the system updates and it said the last one I did was in March. Pushed the button to check for new ones and absolutely nothing happened.
    05-20-2020 12:26 AM
  2. mustang7757's Avatar
    Make sure buttons are free and sticking , can clean with damp damp cloth around buttons ,for things not working like keyboard and other issues try safe mode .
    I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.
    https://forums.androidcentral.com/sh...d.php?t=409154
    05-20-2020 10:04 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Did you already try rebooting? Also, see if the problem persists in Safe Mode: http://www.verizonwireless.com/suppo...e-base-226521/
    05-20-2020 11:06 PM
  1. Should Roblox work on the Pixel 3a?
    By pgg101 in forum Google Pixel 3a & Pixel 3a XL
    Last Post: 05-21-2020, 12:54 PM
  2. Replies: 4
    Last Post: 05-20-2020, 09:30 PM
  3. Replies: 7
    Last Post: 05-20-2020, 07:25 PM
  4. My Files does not show contents of Internal Storage/Download
    Last Post: 05-19-2020, 11:57 PM
  5. Can AI transcriptio work wit phone calls
    Last Post: 05-19-2020, 11:19 PM
