    I bought an Oukitel K7 Pro after reading it was compatible with StraightTalk. Then found out it wasn't so I switched to Verizon and it was also not compatible. I would love to use the phone and it's what I want but I can't find a way to get a carrier. I got to where it would make calls but it won't pick up the internet. I just need to know what carriers work with it please.
    06-07-2020 06:34 PM
  2. mustang7757's Avatar
    If it doesn't work with Verizon I would think GSM like TMO or Att
    I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply
    https://forums.androidcentral.com/sh...d.php?t=409154
    06-07-2020 06:47 PM
  3. hallux's Avatar
    Here is the spec sheet, including the network bands supported by the device -
    https://www.devicespecifications.com/en/model/7a9151bf
    Here is a list of bands in use in the US - https://en.wikipedia.org/wiki/Cellul...cies_in_the_US
    It may actually not be compatible, but maybe someone in here has set it up before.
    If you need additional help or have more questions or details to share, please join the site so you can reply in this thread. See this link for instructions on how to join Android Central.
    06-07-2020 06:52 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! Near the bottom of the page, you can also see the supported bands using the number convention (not the frequency): https://www.oukitel.com/products/k/o...7-pro-118.html. It supports LTE bands 1/2/3/4/5/7/8/12/17/19/20/26/38/39/40/41.
    T-Mobile uses LTE bands 2/4/5/12/66/71, so the overlap there is bands 2/4/5: https://www.t-mobile.com/support/cov...mobile-network. I believe Band 4 is still the backbone of their network, so since the phone supports that band, it'll probably work pretty well on T-Mobile.
    AT&T's LTE bands are 2/4/5/12/14/17/29/30/66, so the overlap there is 2/4/5/12/17: https://www.androidguys.com/guides/r...-and-networks/. Bands 12 and 17 have historically been the backbone for AT&T, so again, the phone should work pretty well on that network.
    Verizon and Sprint are generally more restrictive about the phones they allow on their network, so you're bound to have more difficulty bringing a random unlocked phone into their network.
    06-07-2020 07:18 PM
  1. Replies: 3
    Last Post: 06-08-2020, 09:06 AM
  2. No torch (flashlight) on my Active 2?
    By Android Central Question in forum Samsung Galaxy Watch Active 2
    Last Post: 06-07-2020, 11:34 PM
  3. Kyocera Duraforce Pro 2 AT&T Video Call prompt, despite disabling the feature?
    By Forrest Ozbolt in forum General Help and How To
    Last Post: 06-07-2020, 10:16 PM
  4. Kyocera Duraforce Pro 2 - Wi-Fi won't work anymore.
    Last Post: 06-07-2020, 07:36 PM
  5. How can I spy on my husband's phone?
    Last Post: 06-07-2020, 07:34 PM
