    I have a galaxy A50, and when I try to charge it, it goes up to 22% and stays there forever. I don't know if my phone is actually charging and its a fault with the indicator, or if it's a battery issue.
    06-15-2020 02:06 PM
  2. mustang7757's Avatar
    Let it deplete and charge it again , if doesn't work try safe mode, and if still doesn't perform factory reset.
    I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply
    https://forums.androidcentral.com/sh...d.php?t=409154
    Nostromo79 likes this.
    06-15-2020 02:09 PM
  3. Mooncatt's Avatar
    I would suggest using an app like AccuBattery to see if any current is following into the phone, but my gut reaction is to try a new USB cable. Cables do wear out over time and have this type of symptom.
    06-15-2020 02:25 PM
  1. Replies: 8
    Last Post: 06-21-2020, 09:38 AM
  2. Galaxy S5: Normal battery drain % per hour: what are you getting?
    By alastairlee in forum Samsung Galaxy S5
    Last Post: 06-16-2020, 12:50 AM
  3. Why is my new Gionee M11 not coming on, but is charging?
    Last Post: 06-14-2020, 09:03 PM
  4. Swiftkey typing issue when charging?
    Last Post: 06-14-2020, 01:08 PM
  5. Replies: 6
