    My volume down and power button are broken and don't click anymore, last time I checked the recovery mode is enabled using volume down in my phone, so I can't do the connect charger and hold volume down. Is there any other way I can get it turned on to recover data?
    06-21-2020 03:20 AM
  2. Galactic Zoo's Avatar
    Nope!
    06-21-2020 04:13 AM
  3. mustang7757's Avatar
    You just want recover data? Try going to phone repair shop see if have software tools to extract it
    .I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.
    https://forums.androidcentral.com/sh...d.php?t=409154
    06-21-2020 10:23 AM
  4. B. Diddy's Avatar
    Welcome to Android Central! Repair of the buttons might not cost that much, so get a quote from your local cell repair shop for that as well.
    06-21-2020 05:15 PM
  5. belodion's Avatar
    Also, you could flood-clean them with alcohol. It may work.
    B. Diddy likes this.
    06-21-2020 05:33 PM
  1. Introducing, Bassntuna and LG V40.
    By Bassntuna in forum New to the Forums? Introduce Yourself Here!
    Last Post: 07-15-2020, 09:19 AM
  2. Couldn't verify my Mi account on Redmi 5A, please help.
    By Hackerrmann in forum Ask a Question
    Last Post: 06-22-2020, 01:32 AM
  3. Android privacy concerns, access and advertisements?
    By Ethan Butler-Amos in forum Android 10
    Last Post: 06-21-2020, 08:56 PM
  4. OnePlus 5T Fingerprint sensor doesn't turn on the device?
    By bomboy2121 in forum OnePlus 5 & 5T
    Last Post: 06-21-2020, 02:31 AM
  5. No settings, and message, "Android Settings has stopped." How can I fix this?
    Last Post: 06-20-2020, 11:56 PM
