    I am experiencing a loss of signal only when I leave the phone charging for longer hours(when i m sleeping for example)
    I have done a factory reset and replaced the sim card but thr problem persists.
    The problem happens only when the phone is charging.
    06-24-2020 10:05 AM
  2. mustang7757's Avatar
    Which phone? Are you wireless charging?
    I haven't seen issues with signal and charging, try safe mode
    I'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply
    https://forums.androidcentral.com/sh...d.php?t=409154
    06-24-2020 11:01 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! Are you using the original charging cable and plug? Is this for cell signal only, or also wi-fi?
    06-24-2020 12:23 PM
  4. toni osmani's Avatar
    Only with cell signal and yes i m using the original cable
    06-26-2020 04:16 AM
  5. Kizzy Catwoman's Avatar
    Which phone is it Toni? We really need that information. Thanks
    06-26-2020 05:11 AM
  6. methodman89's Avatar
    Do you have any power saving modes selected under the settings?
    06-26-2020 06:43 AM
  7. toni osmani's Avatar
    Sorry the phone is samsung s10,I have no power saving modes enabled.
    06-26-2020 08:42 AM
  8. mustang7757's Avatar
    So what exactly happens, you say you lose signal, are you not receiving calls?
    06-26-2020 11:29 AM
  9. B. Diddy's Avatar
    Is the phone set to auto-restart at night? http://www.samsung.com/sg/support/mo...n-samsung-s10/
    06-26-2020 11:33 AM
  10. toni osmani's Avatar
    I cant use the 4g 3g or 2g,make calls basicly I cant do anything with the sim card,I have to restart the phone to use the sim card network again
    06-26-2020 11:36 AM
  11. mustang7757's Avatar
    You try resetting network?
    Settings >general management >reset >reset network
    06-26-2020 11:41 AM
  12. toni osmani's Avatar
    No the auto restart is off.
    I tried every software option possible.I think it might be a hardware problem.
    06-26-2020 11:45 AM
  13. B. Diddy's Avatar
    I assume that means you already tried Safe Mode? It might be worth asking your carrier for a replacement SIM, in case that's the problem.
    06-26-2020 11:56 AM
  14. toni osmani's Avatar
    Did that too.
    Also tried another network carrier
    06-26-2020 12:06 PM
  15. mustang7757's Avatar
    Who is your carrier?
    06-26-2020 12:28 PM
  16. toni osmani's Avatar
    I love in Kosovo.We have Ipko and Vala
    06-26-2020 12:28 PM
  17. methodman89's Avatar
    To be sure, check the following screeshot against your settings.
    06-26-2020 12:31 PM
  18. mustang7757's Avatar
    You should stop by if you can have them go over your APN settings
    toni osmani likes this.
    06-26-2020 12:39 PM
  19. toni osmani's Avatar
    To be sure, check the following screeshot against your settings. [IMG=270x555]https://uploads.tapatalk-cdn.com/20200626/3ad599fcf289713da4a248f9190c4cb0.jpg[/url]
    I have the optimized one
    06-26-2020 12:48 PM
  20. methodman89's Avatar
    On the same screen at the bottom, is it off as shown?
    06-26-2020 01:38 PM
  21. toni osmani's Avatar
    On the same screen at the bottom, is it off as shown? [IMG=540x984]https://uploads.tapatalk-cdn.com/20200626/41aa7ee034850586ca0ccd577a8278c4.jpg[/url]
    it s like this
    Attached Thumbnails Can the charging unit cause loss of network signal?-screenshot_20200626-205405_device-care.jpg
    06-26-2020 01:55 PM
  22. methodman89's Avatar
    Other than clearing the cache partition and rebooting, and if that doesn't solve it, trying Safe Mode, you are left with the advice above. Good luck.
    06-26-2020 02:04 PM
  1. Replies: 21
    Last Post: 08-16-2020, 05:44 AM
  2. Lock screen turning off all of a sudden?
    Last Post: 06-26-2020, 05:16 PM
  3. Replies: 2
    Last Post: 06-24-2020, 07:06 AM
  4. Can't control what to copy on Twitter using Samsung A10e?
    By bubblyloops in forum General Help and How To
    Last Post: 06-23-2020, 10:27 PM
